Hi,
I currently have 1GB of OCZ Premier Dual Channel 2x512MB DDR400 PC3200.
Im thinking of upgrading to 2GB of memory but have a few questions first.
1. My Motherboard's (MSI K8N Neo 4 Platinum) manual says that if I fill all the memory bays up the memory speed will drop, which means that I can't buy another dual channel kit. So would just buying a single 1GB stick of ram do the same job without lowering the overall speed of the memory?
2. Is it better to stick with the same make memory? If so I have been struggling to find somewhere that sells the following in the UK: OCZ 1GB Stick
any info/suggestions would be most appreciated.
Regards,
Chris.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Regards,
Chris.
