Coz you had too much traffick that's why. The raid controller with a pair of samsung hdd that's cheap can even give you a huge boost as the traffick is not over the qpi like you would do with a onboard that's a bottleneck plus more traffick over the qpi or DMI. Again it shows you the importance of a disk setup and balance pc in video editing coz the better cpu got beaten by a lower clocked cpu with a better disk setup and due to its bigger bandwidth. The reason why the 2600k don't have that card coz of its limitation it carried over.
The problem here is that you are correct - on a theoretical basis. On a practical basis, however, even the very fastest of the current GeForce GTX series GPUs do not take anywhere near full advantage of even PCI-e x8 bandwidth, let alone x16. In fact, a single GTX 580 barely saturates PCI-e 2.0 x4 bandwidth - and Premiere Pro CS5 does not support SLI at all (only one of the two GPUs is used). Hence, one can use a hardware RAID card in an LGA 1155 platform without losing any performance because of this fact about current GPUs as long as the secondary PCI-e slot runs in x8 mode.
