i run at 1.80v on a slk-800 and i get up to 119F w/e that is in C /me is too lazy to calc thatMav451 said:Yep, though if you want to be really sure...I'd pick up one of those guaranteed stepping (IQYHA) vs. getting a random one from newegg.
Mines a 0352 and if i had a 13X multiplier mod, I could probably do 13 x 200 @ only 1.725 or 1.75. I'm running a SLK800--so the newer Thermalrights with 92mm will can probably handle this a bit better than mine. 1.725Vcore gets me to 43-44C's idle, which isn't bad, but if i had a newer HSF with a 92mm, i would probably be closer to 40-41Cs range.
ryuji said:i run at 1.80v on a slk-800 and i get up to 119F w/e that is in C /me is too lazy to calc that
the slk handles up to like 1.90 no probs... the cpu idles at about 90-100F
when i had it at 2.3 it would do about 100F idle and 119F full load at 1.85v actually.. its stock at 1.80v and full load at 38C average additionaly.. the heat sink measured with accurate probe measures my heat sink temp to be 93 F full load as close to the middle of the sink as i could get itMav451 said:* for reference, my temps @ 1.725 are 43-44 idle, 48-49 load. You also have to remember that i'm running 2500Mhz compared to your 2.3. If you can compare the temps you get @ 1.8V running @ 2.3 to running 1.8V @ 2.0Ghz, you will see what i mean.
Tell me what your results are.
** (i say this b/c when I ran 2Ghz @ 1.725, my temps dropped to 40C's idle, but upon changing my clock dynamically back to 2.5Ghz, the temps went back up again).
..inaudible for most part..
the delta i have on there now... you CANT hear it when the crickets are making noise outside(with windows to my room closed).... or you go more then 4 feet away from it...Mav451 said:Now i see why there's variance.
1) I'm using crappy Asus Probe...whereas, it seems you are using a real sensor?
2) You are using a delta. The fact that you said that the delta is
tells me your case cooling is probably much louder than mine (3 L1A's at full speed, 1 L1A @ 7V).
3) Heatsink temps are a lot cooler than core temps. My Asus probe temps are consistent with MBM temps--the CPU temp from the die, while the 5-6C's lower one (which is more likely to be consistent with your heatsink) represents the temp from the SOCKET sensor.
So delta + heatsink measurement is probably the reason for the discrepancy.
hey.. interested in talking using aim? its faster this way and were not hijacking a thread this way.. pm me if you areMav451 said:now you're really making me interested in that 70mm delta of yours. Could i see some pics of this?
how do i make sure i get one w/ a guaranteed stepping?Mav451 said:Yep, though if you want to be really sure...I'd pick up one of those guaranteed stepping (IQYHA) vs. getting a random one from newegg.
thanks.Mav451 said:http://www.excaliberpc.com/product_info.php?cPath=178_186&products_id=4099
One of the few sites with guaranteed steppings...
