2500xp
Rhino
whats better if u can get tighter timings, 200 by 12 or 166 by 14.5?
no go at 200 by 12, or 166 by 14, tried 200 by 11.5, almost but no, so im stuck at 200 by 11, if u up the volts even though it dont post, will uppin the volts make it post?
Yes, but it will probably run hotter than you want it to. You will probably have to up the volts quite a bit if it doesn't even post.
Try increasing your Vcore to 1.75v
Also, when did you get this Barton? If it was within the last 5 months or so, odds are it's locked up. Make sure the changes you make to the multi are actually taking effects (boot into Windows, check with WCPUID or CPU-Z, shutdown, reboot into Windows and check again)
