24pin extender question
mussafry89
Hey guys,
I was wondering whether it was smart to buy a 24pin extender and sleeve that. The thing is, the sleevng job on my Corsair 1000HX isnt as good as i want it to be. (Too much wire is showing in the end). However, i want to keep the stock sleeving just in case something goes wrong, i dont want to void warrenty or anything. And plus, its cheaper and easier to sleeve a seperate 12" cable :p
So would it be ok to buy the extender, sleeve that, and just use it? Or will there be a performance drop by using an extender?
-Thanks
What do you guys think looks better?
1 big sleeve
2 sleeves
4 sleeves
6 sleeves
or 24 sleeves.
I was thinking of doing, either 6 or 24 :p
I like the "Big Sleeve" look.. But with 6, You wind up with something much different looking..
