2400+ temps
Shawn
Where is good temps on my 2400+? I am currently 49 idle and 54 load around there. WHen should i get worried about my CPU temps?
Heh, when it stops working, worry;) . Seriously, your temps are fine. "Good" temps would be about 10 cooler, but you are not hurting anything at those temps. These things don't fry until like 85C. Of course it will lose stability way before that a either hang or just reboot. Mine runs prime at 49. That's at 2600Mhz and 1.95 vcore though! As long as your CPU is stable, don't sweat it.
Check your BIOS version, and update it. I was running my XP2400+ at 49C to 53C and that was with a Vantec Aerocool, and AS3. I thought what is up.
I updated my BIOS to the latest revision, and it is reporting a better 42C to 46C
It just could be that simple.
Cheers,
I have a ABit NF7 where can i update my BIOS? don't i have to flash my biod and then back it up on a floppy or something?How do i do that. IS it safe to flash my BIOS?
Flash Menu is the easiest way to do it. It is safe, but no method is 100% reliable. You can download FlashMenu from Abit's web site. It is windows based, so no floppy required. It has the option to do a live update via the internet, but I would recommend just downloading the bios file and flashing it from the HD. BTW, a new bios will not make your chip actually run cooler, but it may lower the temps that are reported. Also, Abits are known to report temps anywhere from 10-15 degrees higher than actual. One more important point; never flash your bios while overclocked!
One more thing. I personally would not do a bios update just because the reported temps might off. Most likely, the will still be incorrect after the bios flash. Some people have reported even higer temps after flashing to a more current bios. But it is your machine, so do with it as you will.;)
Why not update your bios?
I'm not saying updating your bios is a bad thing, but needless bios updates are just unnecessary risks. Just personal preferance i guess. I'll certainly upgrade if there are new features to be taken advantage of (I'm using Tictacs modded bios for example), or if something is broken. I just personally don't think temps are worth it as they are still likely to be wrong after the flash.:)
I think its good to update at least once a year, or maybe two depending on whats going on. I just think its good for your system to be up to date, and also its better if you are getting a faster proc.
I guess its really personal preference.
Cheers,
