2400+ Mobile FAILURE !!
paral3ellum
yeah i just got my mobile 2400+ from newegg and yeah it kinda blows. It only overclocks as fast as my old 2100+. runs on about .125 volts lower, but will not overclock anymore.
I'm not too dissapointed though cause i had to replace my cracked 2100+, and i got a baton out of it.... ohh well what can you do ?
from what i hear most of these suckers are overclocking really well so dont get discouraged. i just wanted to let everyone know there is a crappy stepping version floating around. Sorry though i didnt remember to check the stepping before i put on my water block. good luck with your moblies
tell you that the 2400+ isnt a barton
Maybe something else is holding you back. Give us some details. Ram timings, vcore you've tried, prime results, etc. Also 2.4ghz isn't too shabby.
2400+-M's are barton cores just at lower FSB...I get that OC with one too. Let me guess you got an A_____ stepping right? I did too...the I_____ are the ones that get huge speeds. Oh well.
wait I'm probably going to be getting the 2400+ mobile, but now I'm confused with the stepping A thing and the l thing that you guy's are talking about. From what I understand there are certain stepping of the 2400+ mobile that OC very good. Where can I find this stepping?, so when i go to purchase one I know what I'm getting, or is that something I have to find out. Correct me if i'm wrong in anything. Thx
they all OC very well, just some do better. its just luck of the draw which one you get from newegg. theyre all winners really.
