Ok, the VX2025WM (which I thought was discontinued) is now in stock at newegg. Do you guys think I should go through the hassle of the panel lottery or play it safe with the 2025WM? I plan on doing some gaming as well as photoshop and some CAD work. According to the LCDbuyersguide over at anandtech, the 2025 has an A-MVA panel now? Or did it always have it (thought it had a S-PVA panel before)... Not quite sure, that's why I'm asking you guys. Thanks,
-Juce
-Juce
