2005-FPW question!
Circuitbreaker8
Hello all! Just ordered a Dell 2005FPW from Dell last night and I can't friggin' WAIT for it to come in! When Xbox 360 comes out, I plan to hook it up to the 2005FPW, since it supports 720p. What do I need to hook them up? Does the 2005FPW have some sort of hook-up through the back (VGA?) or do I need a seperate converter box?
the 2005FPw comes with 4 inputs, VGA, DVI, Composite, and S-Video, all of which are independant (I believe the VGA is independant of the DVI i dont see any reason it wouldnt be) is the xbox360 going to have VGA out? sorry I dont like xbox. if so you should be all set, i think it would more likely be DVI if that is the case i guess you would need a switch box since you will probalby be using the DVI port for your computer? if you are going to use the VGA port for you computer then the DVI will be free for whatever you want to hook up to it. There is no need for any external stuff then. I love my 2005FPW. i just with the PS2 had VGA/DVI output then we would be rockin.
