2001fp and a ps2
ah yeah, sorry. I just got mine and I misread composite as component.
DJSkankho is right that Svideo would be best.
i would actually use a computer ps2 emulator if possible, to utilize those extra pixels a little bit better with higher quality graphics.
but it depends on why you are using that great monitor with something that doesnt have great output.
are there any WORKING ps2 emulators? the last time i checked, they had some that loaded the bios and stuff...but what good is that. it'd be cool if there's one that actually plays games.
Aesalon said:
you can get a component to vga adapter, might work the best.
this is the one I use for my xbox and my projector.
http://hardware.teamxbox.com/articles/xbox/934/VDigi-Electronics-Enhanced-VDZ3-Review/p1/
all you'd need is the component cables and unfortunately, I'm not too familiar with the PS2. if there are, this would be the best bet in my uninformed opinion.
wow that looks really good (especially with xbox, ngc and ps2 support). may invest in one myself, although i'm finding it hard to find in the UK :(
