My laptop keeps dropping signal a lot so I wonder if I buy a USB/PCMCIA card to put in to get the stronger "STAY CONNECTED", is it true?
If 1 fail the other stays connected, right?
Are there any conflicts if I use both at the same time or I need to disable the built-in?
If both can work they will double the bandwith?
And how about using 3 cards: built-in, USB and PCMCIA or more (there are 4 USB ports on my laptop) to get even better signal?
