I'm not sure that this is the correct place for this so if it isn't, mods please move it.
I have a customer's pc at home that is giving me grey hairs. After cleaning everything else off of it, I still have two rouge instances of IEXPLORE.EXE running in the task manager. When I try to end them, they close and then immediately start up again.
I have already removed quite a few malicious pieces of software as well as viruses but the solution to this is eluding me.
What I have already tried/done:
Updated Adaware 6.0 SE
Updated Spybot S&D
Newest version of CWShredder
Newest version of Stinger
Fully Updated Norton Anti-Virus scan
Unknown version of Webroot SpySweeper scan
I apologize for not being able to post a hijack this log. The computer I am working on is at home and I am now at work.
There are no suspicious processes running in the task manager that could be regenerating IEXPLORE.EXE unless something is running under svchost.
I can't find any suspicious folders on the computer that could point me in a direction to research this further.
Unfortunately I have a couple of handicaps on this repair.
1. There is no NIC in this computer so I can't get it online to run an internet virus scan.
2. I am between houses right now so I don't have unrestricted access to broadband internet.
If anyone knows of any other tools I could use to locate the cause of this I would be very appreciative.
Thanks
Updated Spybot S&D
Thanks
