okay, so here's the deal. I need a soultion for a dual 940 rig that fits in a 1U case. specifically this cse. It needs to fit through the PCI slot, as that's the only feasible solution I see to put the pipes through. I need 2 1U Opteron WBs and preferably a huge pump/radiator that I can mount in a 19" chassis and put to the 12CM fan at the top of the rack.
Is this too much work, or should a good 1U heatsink work fine? like the Alpha U81C? it's at a colo facility where the building is always 70F.
