northrop
grumman
- Sep 27, 2005
Need a 17 LCD gaming solution with DVI within $350.
Is Dell 1704 my best bet?
LordVampyre said:tell you what.. I just got a lcd and at first was looking at 17inch monitors however, compaired to the 19inch monitors gotta go with the 19inch.
If you can might I suggest you check out the 19's cause its much much better.
northrop said:This will be my first LCD, so Im not too knowledgeable about them, but I really like that Viewsonic. Looks like a winner. Thanks for all the input guys.
northrop said:Need a 17 LCD gaming solution with DVI within $350.
