I'm looking for a 160mm radiator template to drill the holes in a u2 server case. The Rad's are the Hardware Labs Black Ice Gen Two Xtreme Micro 160. I'm installing 4 of these rads and need to make 8 fan holes plus 32 screw holes and it would be easier with a template. I found 80mm fan template's but I need a dual 80mm fan setup with a 15.5mm spacing. Something that I could print out like a PDF file instead of trying to tape the 80mm template's together.
Thanks for any help
Thanks for any help
