15 seconds for MB to post
filip
I have a ASUS M5A97 motherboard that I bought earlier this year. The problem is that it is posting so so slow. 15 seconds to see the bios screen and then like 5 more till windows loading screen shows up.
What gives is this just a crappy MB or can I do stuff to make is post faster?
Thanks.
(sorry if this is a stupid post, but I have an asrock and it post in like 1 second)
is a hdd going bad? seems like it is hanging because it is trying to detect a piece of hardware.
Could be a piece of hardware failing. Case in point my DVD-RW was going out, sometimes it wouldn't show up in windows/bios. This caused a massive slowdown in my boot times (from 10secs when working to 25+ seconds).
Simply unplugging the drive solved the problem.
Did you add any new USB hardware? I had much longer POSTs when my SS Xai was connected.
I believe quick boot is enabled but I cannot find it in this particular bios.
I was getting the same post time with HDD disconnected and A new SSD running.
For the hard ware failing: most likely not anything the machine was built earlier this year.
Currently the only USB is the Keyboard and the Mouse....I have disabled usb3.0 in the bios.
Still not getting what I hoped for is this the best the MB can do?
Disconnect everything from the mb (hdds, ssd, roms drives, usb). Boot the pc with just a kb/m attached and see how long it takes. Add one device at a time until you figure out what's wrong.
Ok will do and thank you. I just found out this motherboard dose not have a fast boot option (asus decided to release it a new version of the mother board Rev.2.0)
I'll let you know how it works out.
Ya that's the fastest post I can get(15sec).... Thanks for your help guys.
Ya I have tried every thing. The reason I looked into it is because I tried an ssd and the post time did not please me. Asus let me down.
if there is anything that you arent using (sata controllers, etc.), turn them off in the bios. i know using a secondary sata controller will add time to your boot.
Thanks I have turned the sata's I am not using off....still the same.
I had a huge problem with this and Razer products.
Something about the onboard chip of theirs in their keyboards and mice can make some systems unstable at boot.
After I figured this out I got myself a real mechanical keyboard and logitech mouse and have never had a problem, booting is quick and painless.
Are you using any Razer products? Unplug them and try again.
Thanks again for all the help......I have a dell keyboard at the moment but It dose not slow my other computer when plugged in during boot and the same thing can be said for the logitech mouse I have......Dose any one else have a m5a97 with similar results to mine?
Thanks again.
I was reading a motherboard review recently, and was surprised how several various motherboards took 10-15 seconds. My own Asus P8P67 is also a snail to post. Your motherboard is probably fine.
