1300$ Gaming PC Build help
Visec
I don't need a Monitor, Hardrive, Mouse, Keyboard. I plan on Oc'ing. I'd prefer to keep things under 1300$ but will go as high as 1500 if performance increase is quite significant so whatever is the best bang for the buck with overclocking in mind. I've been out of the loop for a couple years and have no clue whats hot now days I need assistance constructing a game specific rig that will play next few years hottest gaming titles. Previously Newegg was the #1 best spot to purchase online parts [Hard]posters would fill out a Newegg form and post it here but has Neweggs Superpower status changed?
Help is greatly needed multiple suggestions are welcomed.
Hey there!
Newegg is still numero uno in my book.
Before we start: what kind of monitor will you be using? The native res will make a difference in which video card will best suit you.
Though, at that price you could just overkill the video card and make it last many years. heh.
A rough outline:
Q6600 (quad core intel chip) - $285
4gb ddr2 800 (super talent has 2x1gb kit cas 4 for $94) - $188
motherboard (dunno a good one really) - $150-250
Raptor hard drive? OEM 150gb - $190
Sata dvd drive - $35-50
Quality PSU (dunno a good one really) - $150-200
LIAN LI CASE!!! :) - $100-200, depending on which one...
8800GTS 640mb or GTX (though 8900 series is coming soon...? not up to date on this) $380 / $ $500
Should have no problem building one badass rig for $1300-1500.
I'm sure others will me more helpful.
Well, normally it's better if the OP posts a list that they made up and it's worked on here..but oh well.
The monitor resolution question is going to need an answer, but we can start with some specifics here:
A rough outline:
Motherboard - Abit's IP35 line, Gigabyte's P35 line, or Asus P5K line all perform similarly. Pick a board with the features you want..although the higher end boards *tend* to overclock a little better.
Raptor - Overpriced, not enough of a speed gain to offset the loss in storage space and price premium
Hard drive - technically, WD's AAKS and Seagate's 7200.10 drives perform the best...but I just like to grab good deals on drives. Your call.
PSU - depends on video setup, Corsair's 520w or 620w models should be a pretty good place to start ( yes..they're mentioned quite a lot )
Video - G90 isn't coming for two more months, so i don't think it can be considered yet. :p
I'm using a 2 yr old 19" dell crt right now. Is there a new style monitor or something out now that will compliment current rigs more? Last I checked (a few years ago) a monitor was pretty much just a monitor and nothing special there was just crt and flatscreen and a CRT gave the same performance and flatscreens were for convenience nothing else. Not sure if things changed. I'll drop a few hundred if theres current monitors providing better quality but I don't necessarily need a convenienced flatscreen.
P.S. If someone would like to fill out a newegg form and post it here it would make ordering things alot easier but suggestions like above will do ;)
Well there are 22" widescreen LCD monitors for about $250 these days ... wide screen gaming is the way to go.
People ask for the monitor to check whether the video card will be able to handle the resolution. ;)
Anyway, most of the time, there are many pieces of hardware that will perform similarly and it's eventually up to the user to pick which ones they like. This is especially true for motherboards, RAM, and processors right now. It's like choosing between a pen, pencil, or cutting your finger for taking notes, they'll all perform the task...just pick one you like.
Anyway, at that resolution I'm pretty sure a 8800GTS 320MB should be good.
However..it seems like you really want someone to assemble a list..
Q6600
Abit IP35-Pro
4×1GB DDR2-800
8800GTS 320MB
CorsairHX 520W
320GB WD AAKS or 7200.10
Thermalright Ultra 120
Newegg isn't the cheapest anymore, I like to shop around...some people don't like shopping around. I'll list some sites anyway: mwave, clubit, and zipzoomfly for the hardware. jab-tech, svc, coolerguys, and performance-pcs tend to be the cheapest for cooling/cases/modding stuff.
Keep in mind if you go with 4GB of RAM, you will need a 64-bit OS. Also, I'd recommend going with 2x2GB kits instead of 4x1GB kits. It will be a bit more expensive, but it leaves 2 memory slots open so if you need to add more RAM in the future you can without having to discard any current RAM.
You can definitely save some money by shopping around. I use pricegrabber.com a lot to find the best prices, but NewEgg is usually pretty close if they aren't the cheapest. It depends on how tight your budget is. If you have some room to spare, it is convenient to get everything at one place with good customer service. If you are squeezing every penny, you can save some money by buying each part at whichever place has it for less. It seems that usually NewEgg, ZipZoomFly, ClubIT, MWave or SVC are the cheapest on the parts I've looked at.
Also, on the mobo the Abit IP35 Pro is the most popular board right now. However, I was helping a friend spec out his new box yesterday and we discovered that many places are out of them right now and those that aren't had price increases. I bought mine a few weeks ago from NewEgg for $184.99. Now, they have it for $209.99 and as of yesterday, MWave and ZZF were out of them.
Disregard this part of my post. Apparently that price jump was just because mwave and zzf were out. They have both restocked and newegg has lowered their price back down to $184.99.
