127C ???
fuzzy34
Am I Really Still [H]ere?
I just got speedfan, but im not sure what temperatures are what...
What are temps 1 and 2? and why are they that high? :confused:
I don't think anything in the computer can stand that kind of heat. And is it just me, or is 127 the largest 7-bit number? Maybe something went wrong and the thing just reported a convenient number.
Its on fire!! lol
But seriously, Are you sure that the program supports your mobo??
BTW, I can smell the smoke here in my room...
tikicult said:
Its on fire!! lol
Nah, it's just your weed lol.
jaykay, jaykay.
tikicult said:
Its on fire!! lol
im not sure if the program does support my mobo or not, i just knew the program was popular on here, so i decided to give it a try
and btw, your computer runs hotter than mine, turn up your dang fans!!
im thinking that temp 1&2 just dont exist, temp1 at the bottom is my proc, and temp3 is my ambient..
I'm not sure what those are but no your machine would not handle those temps. I believe it would be on fire. 127C = 260.6F. :eek:
i dont know....i could always make a personal pizza in my spare 5 1/2 bay if those temps were real :cool: :D
but yeah, thats what i thought too
edit: I thought about it some more, and I think that the 40C is my processor, while Temp3 is my ambient. As far as the other ones are, who knows....
Yeah, you might be right. That can be the raw data reported by SMART. In that case, 127 ain't bad at all.
The 127 generally means that the sensor or that portion of the IC is not implemented, I get that on some ECS/PCChips boards which are known to not have fully implemented hardware monitoring.
So you are getting a phantom reading.
makes sense, thanks
To find out which one is your CPU temp, run a stress test like Prime95. It should go up rather quickly.
tikicult said:
So you're saying that its a ghost?? And its on fire??
*runs for the hills
Nope, I have dealt with a similar circuit at work, it reads analog channels before they are filtered etc..., when you disconnect the ribbon cable, the circuit is left open and there are odd readings, the reason why is there is a bit of bias on the circuit that comes from the entire circuit itself. To remove the odd reading you simply tie the input to ground and the reading goes away.
yea so when you find the ribbon cable to your cpu, just tie it to ground and everything will be fine. good luck with that.
lol, :p
