OneEyeWilly
- Nov 29, 2009
Hi everyone.I need your advice on a gaming PC.
Budget- I would like to keep my budget at around 1200.00 dollars.I am willing to go up anther $100.00 dollars if needed,but would like to try to stay at 1200.00
I need some help on my first build.I will be starting this build in early January of 2010.I am building this pc for gaming.I download 24/7,so this might be a consideration.I have alot of pc games,but I want to play older games up to the very latest games (ie) Modern Warfare 2 ect..at medium to max settings.I am willing to spend a few more dollars for the best dual core.I'm really debating between the Wolfdale E8600 vs the E8500. $269.00 vs 189.00 is a big price difference.The one thing I heard about the E8600 that really appeals to me is that overclocking is a breeze.I read alot of reviews from various sources.I have never overclocked,but I heard by just changing the multiplier on the E8600 you can get this chip to 4 gigs easy without messing with any other settings.On the otherhand,lets say I go with the E8500,and I don't overclock.Will this give my enough power.
I will be using XP for my OS,which I bought a few months ago for the purpose of Gaming.I still need 4 gigs of ram.I know xp will not use it all,but I want 4 gigs all the same.As far as the specs with the monitor it's default is 1920 x 1080 with a response time of 2ms.I like that alot.
So I still need:
Ram
Video card
I really like prices on the ATI video cards,but Nivida seems much more compatible for my purposes.Old and new games
Finally.I bought a Antec 900 awhile ago,and plan on using that case to build another pc with the i7 set-up.Of course I will be using windows 7 for that build,but I let the prices drop and find a good medium in price some time in the middle of 2010.
Here are most of my parts...
Antec Twelve Hundred Black Steel ATX Full Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358
LG W2453V-PF Black 24" 2ms(GTG) HDMI Full HD 1080P Widescreen LCD Monitor 300 cd/m2 50000:1 w/ Smart Package - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16824005126
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 power
http://www.newegg.com/Product/ProductReview.aspx?Item=N82E16817139006
XIGMATEK HDT-S1284EE 120mm Rifle CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233023
Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136296
PLEXTOR 24X DVD/CD Writer Black SATA Model PX-880SA LightScribe Support - OEM
http://www.newegg.com/Product/Produ...tDeals&SubCategory=5&StoreType=2&N=2010100005
Case 150.00
CPU 190.00 Priced for E8500,but really undecided
CPU Cooler 40.00
Mobo 130.00
Monitor 270.00
Hard Drive 160.00
CD Burner 45.00
PSU 110.00
Total $951.00
So I still need:
Ram
Video card
Case 150.00
CPU Cooler 40.00
Mobo 130.00
Monitor 270.00
Hard Drive 160.00
CD Burner 45.00
PSU 110.00
Total $951.00
