Captain Colonoscopy
- Feb 19, 2004
I have this idea to mount a 12" desk fan into the side panel of an old hydralic case I have laying around. I started thinking that this would be a great idea but then I realized most desk fans don't have molex connectors. Does anyone know if an ATX power supply could run a desk fan? I assume one could solder the power cord from the fan to the proper +/-/ground wires on one of the 4-wire leads, perhaps? Another idea I had was to get a PSU that has a 2-prong outlet on the back of it and run the cord through the inside and out the back of the case to plug it in. That would probably be easier but would look kind of ghetto. I was thinking about using the rear half of the desk fan grill assembly to mount to the side panel with that auto glass molding that comes in the pre-cut window kits. The fan has the speed control right on the back of that thing so I'd have a built-in rheobus kinda.
I then plan on putting 2 or 3 120mm exhaust fans in the top of the case and maybe keep the 60mm rear exhaust that came with it as well. I figure I might be able to run a passive zalman cooler on the CPU and GPU with this kind of setup.
What do you guys think? I'm probably going to do it after I finish my current project (still priming/sanding) just because I'm never going to use that hokey hydralic case for anything and I'm itching to hack something up with my dremel again.
I'm thinking it will prolly be loud, but hey, who else has a 12" fan in their case?!!
