Enduring_Warrior
- Sep 22, 2004
What Up!!
I recently bought an X360 and have had the E-74 hardware error a couple of times. For I have found out, it seems to be a prob with the power source. Only turning off and on the console has fixed it so far.
What do you recommend:
1: Turn it back for checking, they will give it back after 15 days changing it "if the console is defective"
2: Don not pay much attention. I've read that this one is the most common error on the console, and I have managed to fix it without even following the recommendations given by Microsoft.
Another issue is the Wireless controller which while using the console flashes its circle of light as it was seeking for the console signal. "Interference" or a faulty controller?
Thanks a lot in advance.
