klipsch4.1
- Mar 28, 2004
I have the Creative X-Fi XtremeMusic sound card and I was looking for a good pinout to make the connection from the Creative Proprietary Connector on top of the sound card to the front-panel audio port on my case (Antec 300). I know that this site exists, but I've heard mixed things about the mod not working 100%.
I have made one cable, but it appears to only half the power to the headphone jack & mute the rear speakers. After doing extensive searching through forums & whatnot, I've come to find the following information regarding the pinout of the connector on the X-Fi as well as the standard AC'97 & HD Audio connectors.
Creative Proprietary Connector Pinout:
***** FRONT OF CASE *****
01 - AUD GND
02 - FP Out (L)
03 - Audio Mute (L)
04 - FP Out (R)
05 - Audio Mute (R)
06 - MIC
07 -
08 - MIC BIAS
09 - MIC Mute
10 - Cable Detect
***** REAR OF CASE *****
AC'97 Pinout:
01 - MIC
02 - GND
03 - MIC_Bias
04 - GND
05 - Out (R)
06 - Return (R)
07 - +5V
08 - KEYED/NOT USED
09 - Out (L)
10 - Return (L)
HD Audio Pinout:
01 - MIC (L)
02 - GND
03 - MIC (R)
04 - Presence
05 - Out (R)
06 - Return (R)
07 - Sense
08 - KEYED/NOT USED
09 - Out (L)
10 - Return (L)
So far I've tried the following pin-to-pin connection:
X-Fi ----> Front Panel Connector
01 ----> 02
02 ----> 09
03 ----> 10
04 ----> 05
05 ----> 06
06 ----> 01
08 ----> 03
All I get with this config is that when I plug headphones into the front port, the volume/power seems to get halved. What I'm trying to do is the following:
1) When I plug headphones into the front panel, the rear output mutes
2) Be able to not have anything plugged into the front panel for the rear to work (I've seen some mods that require you to have an empty connector in the front panel for the cable to work)
If anyone has any suggestions, let me know, I hate to have an X-Fi soundcard, a nice case, and to have the front panel audio connectors be useless. I could just use the onboard audio, but I have an X-Fi, so why not use it?
Thanks in advance
& Oh yeah, my system below is old & out of date, I'm currently in the process of building a new rig and I plan to move my X-Fi to it.
Asus P5Q Pro
Q9550 w/ Actic Freezer 7 Pro
OCZ Platinum Edition 4GB (2x2GB) DDR2 1000MHz (PC2-8000)
Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM SATA
VisionTek ATI HD 4870 512MB w/ ZALMAN VF1000 2 Ball VGA Cooler
LG 20X DVD±R SATA / X-Fi XtremeMusic
Antec 300 Case / FSP 600W
01 - AUD GND
02 - FP Out (L)
03 - Audio Mute (L)
04 - FP Out (R)
05 - Audio Mute (R)
06 - MIC
07 -
08 - MIC BIAS
09 - MIC Mute
10 - Cable Detect
AC'97 Pinout:
01 - MIC
02 - GND
03 - MIC_Bias
04 - GND
05 - Out (R)
06 - Return (R)
07 - +5V
08 - KEYED/NOT USED
09 - Out (L)
10 - Return (L)
HD Audio Pinout:
01 - MIC (L)
02 - GND
03 - MIC (R)
04 - Presence
05 - Out (R)
06 - Return (R)
07 - Sense
08 - KEYED/NOT USED
09 - Out (L)
10 - Return (L)
01 ----> 02
02 ----> 09
03 ----> 10
04 ----> 05
05 ----> 06
06 ----> 01
08 ----> 03
Thanks in advance
Asus P5Q Pro
