https://overclock3d.net/news/gpu-di...mance-gains-using-work-graphs-with-radeon-gpu
https://developer.nvidia.com/blog/advancing-gpu-driven-rendering-with-work-graphs-in-direct3d-12/
https://developer.nvidia.com/blog/work-graphs-in-direct3d-12-a-case-study-of-deferred-shading/
https://github.com/NVIDIAGameWorks/donut_examples/tree/main/examples/work_graphs
https://overclock3d.net/news/softwa...ure-could-make-future-games-less-cpu-limited/
With the proliferation of GPU-driven rendering techniques – such as Nanite in Unreal Engine 5 – the role of the CPU is trending towards primarily resource management and hazard tracking, with only a fraction of time spent generating GPU commands. Prior to D3D12 Work Graphs, it was difficult to perform fine-grained memory management on the GPU, which meant it was practically impossible to support algorithms with dynamic work expansion. Even simple long chains of sequential compute work could result in a significant synchronization and memory overhead.
GPU-driven rendering was accomplished by the CPU having to guess what temporary allocations were needed by the GPU, often over-allocating to the worst case, and using previous frame readback for refinement. Any workloads with dynamic expansion either meant issuing worst case dispatches from the CPU, having the GPU early out of unnecessary work, or non-portable techniques were used, like persistent threads.
With Work Graphs, complex pipelines that are highly variable in terms of overall “shape” can now run efficiently on the GPU, with the scheduler taking care of synchronization and data flow. This is especially important for producer-consumer pipelines, which are very common in rendering algorithms. The programming model also becomes significantly simpler for developers, as complex resource and barrier management code is moved from the application into the Work Graph runtime.
We have been advocating for something like this for a number of years, and it is very exciting to finally see the release of Work Graphs.
DX12 with the latest Agility update supports them but it will be a good while before games start using them as they have to be built with this rendering method in mind.
