Hi guys,
It has been a few years (~5) since I built a new rig (I really extended the life of my old one) so I did some research on motherboards and ended up going with the z68 for my new one I put together last night, specifically: Asus P8Z68-V Pro (review done in May here: http://www.hardocp.com/article/2011/05/11/asus_p8z68v_pro_z68_chipset_motherboard_review )
My question is I'm a little confused about the SATA controllers on this thing. There is a "Marvel" and an Intel SATA controller, and in the BIOS it shows only the Intel controller having 6gb/s functionality. So I plugged my Crucial SSD into that controller (I also have a 1TB platter drive plugged into the other Intel 6gb/s channel.)
I then slapped my dvd drive onto the Intel 3gb/s controller channel and attempted a boot. I had a Win7 bootable disc in the drive, but the system didn't seem to recognize it as such. I'm used to seeing the "hit any button to boot from this drive" OR "no operating system found" text showing up at some point, but basically BIOS recognizes all drives, but after it gets through all sequences it just sits at a prompt blinking.
It was late last night when I got to first boot, so I have a lot more work to do in troubleshooting, but the first thing I did was moved the dvd drive to the marvel controller just to see if that made a difference. It didn't seem to. Ultimately I got it to boot off the dvd drive by putting my win xp cd in the drive... so it makes me think that my controllers aren't seeing the win7 boot files for some reason?
I found a file on ASUS' site that also shows a Marvel 6gb/s sata driver for Win7, so I'm wondering if I should install that and move my hard drives over to the Marvel controller? Does it matter?
Any thoughts are appreciated. Today at work I actually copied my win7 contents to both a flash drive and my SSD, so I think I'm more prepared for this evening when I get home.
Thank you!
ETA: I also brought this up because I heard some quibbles that sometimes these two controllers don't work quite right simultaneously... but I thought that was only if you were trying to use them both in RAID configurations at the same time, which I'm not using either of them in RAID at the moment.
ETA2: Just a random update for anyone who might stumble across this later. There is a minor asterisk in the mobo manual that says "Marvell controller does not support ATAPI devices," so I'll have to ensure my DVD drive isn't sitting on that controller. Although I could swear that I had it plugged into both the Intel and Marvel controllers at one point, and BIOS detected it the same way on either one...
Thank you!
