I'm looking ot upgrade my 2500k system to a haswell. I'll be going with a single gpu (r9 390 or whatever can drive a 1440p reasonably well).
What I would like from the board is reasonable number of fan headers; very good audio (most have decent audio but a few seem to have issues); very reliable and hassle free service if there is an issue. I do not intend on focusing on overclock but might get a K cpu if it is cheaper than the non-k (microcenter). Undecided if I will go with i5 or i7; I know the 4970k runs very hot with stock cooler (I will be using stock cooler).
Some of the motherboards I've leaning towards are:
msi gaming 5 (seems ok but slow boots - $130ish)
gigabyte gaming 7 (one review suggested the audio had interference issues) ($125) (seems to have low failure rate)
asrock extreme 4 (seems to be a bit power hungry and modest failure rate but has intel nic - prefer intel over killer)
msi power max (high end board for not too much $ - $160)
asrock fatality (so many variants hard to tell which one is reliable)
I do not care about esata; m.2 or usb 3.1; 6 sata ports are plenty. I do care that he board is reliable; stable and runs cool (some of the boards boost the cpu above recommended threshold at default settings to 'win' benchmarks).
I'm open to other suggestions as I'm having a bit of an issue dealing with the gazillion reviews I've read the past 2 weeks. My concern with some of the $100 dollar boards is that they won't last 5 years but if one is well made and has good audio I don't need a lot of extra features. Also the more expensive boards seem to have dropped a lot in price since skylake was released (i have already decided skylake doesn't justify the cost for myself).
