I am building a new i7 rig, and having tough time deciding which case to go with.
LIAN LI Lancool PC-K62 Black 0.8 mm SECC, Plastic + Mesh ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112239
LIAN LI ARMORSUIT PC-P50 Black Aluminum ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112240
Does aluminum case does a better job in dissipating heat? Would the PC-P50 retain a better value (if I decided to sell it later on)? What other benefits would I get in getting the PC-P50 over the K62? In short, is the PC-P50 worth $60 more (from another place) than the K62?
Thanks.
Thanks.
