devil_trigger
- Jan 24, 2007
Ok guys, I've been lurking this forum for awhile and I know you guys tell alot of people to post back when they are going to purchase the computer. Well I'm going to be a little different because I've been out of the game for awhile and I usually build my PCs by gathering pieces little by little for a couple or few months. Now I know you are going to say thats a bad way to go about it because tech changes but I build a new PC about every 4-5 years so I'm not too worried about that. I just hope you guys will work with me this way since its the only way I can do this.
Now onto the details. Like I said I haven't built a PC in about 4 years with the system in my sig, C2D E6600, 8800GTX, 2 gigs RAM. I also want to get this stuff figured out ahead of time because I will be WCing this rig and I would like to have a GFX card and CPU picked out so I can pick waterblocks and stuff.
Moderate gaming, very light video editing, web surfing, DVD/CD burning
I don't really know what to set for a budget since this will be spread out like I said, so I can change pieces around if need be. I'm not looking for anything too crazy altogether, something moderate like a mid-range PC. I'll throw $1000 out there w/o shipping and tax.
3) Where do you live?
Mantua, NJ - Veeerrryyyy close to a newegg shipping location.
CPU, GPU(1), RAM, Mobo, 2x DVD-RW drives and they dont need to be special
Thermaltake Toughpower 850W modular https://thermaltakeusa.com/Product.aspx?S=1207&ID=1503 1 Samsung spinpoint 500GB SATA HDD, monitor, Creative X-Fi Lian-Li G70 case
6) Will you be overclocking?
If its as easy as OCing with the Intel Bad Axe 2 and E6600 I would like to.
Dell 24" 1920x1200
Will be buying piece by piece over a couple months(please work with me on this)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
I dont use raid, I would like the option of Xfire/SLI with whichever GPU is chosen, USB 3.0 and SATA 6gb would be nice if thats what newer drives require
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Windows 7 Ultimate 32-bit
Like I said I dont mind that tech will evolve every couple months or whatever I just want to build this piece by piece. I just want to get some ideas together about brands and chipsets and all that since I've been out of the game for awhile. I am curious if IDE optical drives are still the norm or did SATA finally take over? I know with my current rig I'm using IDE drives since SATA was tricky to use with the optical drives back then for some reason.
I would like to get to know the steps of video cards if someone would be so kind, since about the 8800gtx because I have no clue how the progression went since then. I have no idea how the newer cards rank.
Dell 24" 1920x1200
