Silverstone GD04/GD05 video card clearance
Hello Forums,
This is my first post here; hopefully it's a reasonable one.
I'm currently planning out an HTPC for the New Year, and I'd like to get the best passively cooled AMD video card I can accomodate.
The case is definitely going to be a Silverstone GD05. I was looking at this GPU:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814161392
Does anyone know if it's too tall to fit in the case? Looking at this picture (http://img.photobucket.com/albums/v218/u238blahman/GD05/DSC00006.jpg) posted in another thread, there's some clearance above the PCI bracket, but not a lot.
If the 6670 won't fit, HIS also makes a 6570 low clearance passive card. I'll probably go with that instead.
Thanks for any input!
I have the Silverstone GD05 and a GIGABYTE GA-Z68MA-D2H-B3 mobo it has plenty of room for your card.
