StoleMyOwnCar
- Sep 30, 2013
https://imgur.com/a/3nqkm
Bought a motherboard off Ebay. At first glance things looked good. The IO plate wasn't even out of the wrapper (which only rips open, you can't reseal it). Then obviously the first concern was pins. I went and took some good overhead shots of the board.
To be honest the amount of deviation of the pins in general did not seem to be large, but I don't think these have any room for manufacturing defects, do they? These look like someone had corrected them at some point. For something that they charged 130$ for, I don't think I should be getting a product with bent pins. How do these look to you folks? I plan to open a case shortly to make sure they can't claim that I did it.
