I can't find a review that compares the two and they cost exactly the same on newegg and seem to give similar performance...
Ninja Pro
http://www.newegg.com/Product/Product.asp?Item=N82E16835185001
Mine
http://www.newegg.com/Product/Product.asp?Item=N82E16835185023
The only difference I've found is that the Mine appears to be slightly easier to mount, but that's not really a big deal. Can anyone shed some light on any real differences between these two? I'm planning to use one or the other for a Conroe setup. Thanks.
Ninja Pro
Mine
