OlIv0rIolI
- Dec 2, 2005
I have a water cooling radiator setup on the back of my case so there is a tight small space on the back of my video card's dvi port where normall dvi cable heads wont be able to fit. I need a right angle dvi cable. I found some places that sell them. Problem is I don't know how trust worthy these stores are.
http://www.pcconnection.com/IPA/Sho...448&srccode=cii_9324560&cpncode=24-45298150-2
http://www.pacificcable.com/DVI.htm#DVI-D_Dual_Link_Right_Angle. I couldn't tell from the picture which side the dvi connecting pin are oriented ???
I also found some adaptars that cost 16 at http://www.svideo.com/dvirightangle1.html
Your experiences with these stores are apprieciated or if you know a place that sells them cheap please let me know
