Hi, I have two pc's next to each other that I would like to hook up such that if I reboot pc A, then pc B is reset. (I say reset because I don't need it to reboot the OS, just a physical reset is what I'm looking for). I would like this to occur not through software but via some hard wiring between the two pc's. The reset of pc B needs to occur either by a software reboot of A (eg., restart command in windows) or by pressing the reset button on A.
Does anyone have any thoughts? I tried Add2PSU, but the issue is that it only turns off the power in B when A is powered off. If I reboot A, B stays on and does not reset.
Thanks!
Thanks!
