Hi there.
My trusty HP LP3065 30" has decided to stop working after almost 10 years of hard daily use but I was looking for an opportunity to jump into the 4K bandwagon anyway.
To my surprise thought buying a monitor these days is not that simple it seems. I have spent most of the day trying to catch up with the latest display advancements and for my needs I have decided to get a 32" 4K monitor.
I won't be playing games and the monitor will be used for productivity purposes with software like Adobe Illustrator, Photoshop, Autocad, MS Office Applications, web authoring and light development and in the future 3ds Max.
I also produce and/or approve material for printing so color accuracy is good to have. With that said and having read many reviews about 4K monitors today I have decided to go with the Dell Ultrasharp UP3216Q that also supports almost full Adobe RGB (wide gamut). I don't want to go with a very expensive NEC or EISO display since I prefer to upgrade again within the next 2 years when better (i.e. OLED) displays with DP 1.3 or higher are available and with higher refresh rates.
I was also looking at the 4K 40" Philips as well as the upcoming 43" model but neither supports full Adobe RGB color space and they might be very large after all.
What do think? Any recommendations?
