n64man120 said:Good to hear, I've got 8 arriving tomorrow. Is it a better idea to go 16? I mean both sides of the ram need cooling, but $40 is hard to justify.
in my oppinion theyre the only ones worth a damn...and they are absolutely necessary if your planning on watercooling your video card unless you get a water block that cools the ram as wellBigDaddy85 said:ocz copper bga, they kick azz.
thats just cause they dont cost as much...thats like saying a car is more important than gasoline cuz it costs more when in reality they are just as important...n64man120 said:No, I don't think it's as important. I think it's very important, but your talking $40 for some sinks compared to the $50 I dropped on a whole waterblock.
Tiny said:http://hardforum.com/showthread.php?t=752713&page=1&pp=20
$11.40 got me 8 ramsinks and a NB sink shipped.
Pretty cool. (no pun intended)
Budzman said:Gonna be setting up my 7800's with DangerDen water blocks. However i'm not sure if I should get some ramsinks for the ram. I don't think they would really help that much but correct me if i'm wrong.
BULLSHIT....not only does my x850xt even when not overclocked require good ramsinks but it has to have good airflow over those ramsinks as well...i have a fan mounted in my side panel that blows directly across the ramsinks and one time i forgot to plug it in after some maintenence and after about 20 min of cs:s the game started artifacting like crazy and this is when the card was not oced....it is a big myth thats modern cards dont require ram coolingAACDIRECT said:On the 7800 cards you should run them. The ram gets very very hot even with them on. I would add them to ensure that the ram does not overheat with continued use. On a X850. You don't need them as the ram does not get hot. Both cards being cooled with Maze 4 GPU.
(BTW If you use DD Maze4 GPU Low Profile blocks for SLI you will need to cut down one ram sink per card as it hits on a fitting on the block. Using OCZ ramsinks)
CleanSlate said:These are really good I hear
And $40?? wow. Take those back. 8 ramsinks wouldn't do anything... since all the ram is running at the same speeds. you'd have to have 16.
~Adam
I concur.. I have a 6800 ultra with ram at 1.2 ghz stock. It *will not* run without ram sinks. I had one come off and it would hard lock the computer after just a couple of minutes. I replaced the ram sink and I was back to blissfull stability.cell_491 said:BULLSHIT....not only does my x850xt even when not overclocked require good ramsinks but it has to have good airflow over those ramsinks as well...i have a fan mounted in my side panel that blows directly across the ramsinks and one time i forgot to plug it in after some maintenence and after about 20 min of cs:s the game started artifacting like crazy and this is when the card was not oced....it is a big myth thats modern cards dont require ram cooling
yup i had a 6800gt for awhile that would do the same thing if there was no airflow over the ramsinksdekard said:I concur.. I have a 6800 ultra with ram at 1.2 ghz stock. It *will not* run without ram sinks. I had one come off and it would hard lock the computer after just a couple of minutes. I replaced the ram sink and I was back to blissfull stability.
yea all you need is 8 but i would go with the ocz ones and trim them down if you have toRuss said:here are some $10 ramsinks (8) that aren't teh OCZ ones, so I expect them to not have clearance issures with the waterblocks:
http://www.case-mod.com/store/vantec-iceberq-copper-bga-ramsinks-p-822.html
Vantec Iceburg BGA ramsinks.
And you CAN'T use 16 ramsinks on 1 card. Not normal cards anyway. So be quiet about all that.
dude...dont risk it, seriously...do it right and put good ramsinks on your cardsBudzman said:I got good airflow, 2 92mm fans blowing directly onto my cards from the side panel so that should help.
Gonna try the cards without them first then if there are overclocking problems i'll pick some up. I'll post results.
thats a bad idea.. don't do it..Budzman said:I got good airflow, 2 92mm fans blowing directly onto my cards from the side panel so that should help.
Let me be the third to say "have fun frying your cards." Let's put it this way, if the OEM puts heatsinks on a card for STOCK operation, how far do you think you're going to get without them? These people kind of do this for a living. For a lousy $25 you're going to risk burning out two $500+ cards? I'll stop thereBudzman said:I got good airflow, 2 92mm fans blowing directly onto my cards from the side panel so that should help.
xdkimx said:old thread, but i have a quick question, is this true?
"(BTW If you use DD Maze4 GPU Low Profile blocks for SLI you will need to cut down one ram sink per card as it hits on a fitting on the block. Using OCZ ramsinks)"
i was going to get these ocz sinks but i have the lp maze4 will they fit? maybe someone that uses the maze4 lp can help me out
thanks
Dark_fire said:on the 7800GTX 512 all the ram is under the heatsink by the core
