How come some manufacturers go out of their way to make insane claims like 600W at 25C when they know that there is no way the average temp rating inside a computer case is 25C? My case runs closer to 38C ambient and 44C load internal temps, and I have fairly good airflow.
Also, why do so few manufacturers rate their PSUs realistically?
I know that a few, like PC Power & Cooling and Seasonic rate their power at 50C, which is what I think the industry standard should be, but having a PSU rated at 25C just hurts everyone, because you buy what you think is a 500W PSU that should power your system, and suddenly you find out it was rated for 25C and at 40C in my case it's suddenly only outputting 310W instead of 500W and actually has such shitty efficiency that it is dumping heat into the case and my average ambient temp goes UP while my stability goes down.
Nice way to spend $50, right? I bought a Seasonic S12-500 to replace it, my ambient temp dropped 4C on average, and it's much quieter, not to mention I can now play Oblivion for more than 35 minutes without having random lockups and hearing the fan spinning at super-high speeds.
So does anybody know what temps a variety of PSUs are rated at?
PC Power & Cooling: 50C
Silverstone: 40C or 50C depending on model
Seasonic: 50C
Antec: NeoHE is 50C, TruePower II: who knows?
OCZ: ?
Enermax: ?
Hiper Type-R: ?
Is there some sort of compendium you can go to that will show you this information? Some manufacturers don't list it anywhere on their websites or product spec sheets.
BTW, this is not for the system in my sig, this is for another system I have been messing around with for a friend.
Seasonic: 50C
OCZ: ?
Enermax: ?
Hiper Type-R: ?
