W.O.T. Stang
- Aug 4, 2003
I recently upgraded to 4Gb 1066 DDR2 G.skill RAM which is advertised at 5-5-5-15 @ 2.1v and 1066Mhz.
My board didnt auto recognize it as 1066, only 800. I entered the BIOS and set it manually to 1066, 2.1v, and 5-5-5-15 timings. Upon reboot, i get "BAD CHECKSUM ERROR" and i have to reset all of my BIOS settings.
It runs perfectly with 5-7-7-20 timings (the default), but anything other then that, or a 1T command rate causes the same problem as above. I also did a bit of searching and found im not the only with this problem
Just curious if anyone out there has the same setup, or knows of any resolution to the problem. It's not a huge deal to me, but it would be nice to run it at what it's rated for.
