Quiz
- Aug 25, 2010
Yes, I was already aware of that.There are no user serviceable parts on a Mac. And generally the cost of any repair will be higher than on a PC.
tl;dr below.That's the nice thing about (service).
Need for service is usually non existent outside of user error!
Not specified, you would have to call them.Does the power supply for the CalDigit Element Hub support universal voltage? Can I buy one from the US (110-120V) and use it where I am (220-230V)?
Thanks.Not specified, you would have to call them.
Most switch mode supplies today will run on ac 50-60Hz and DC with input voltage range 85 to 270 volts however. It will be printed on the adapter.
No. I don't even think it works well on iPad Pro.Do you guys use Stage Manager?
I got the CalDigit Element Hub about a week ago.
I have a question regarding charging. When I didn't have the Element Hub yet, I had my original Apple charger connected to my MacBook (which is used on a desk 24/7 plugged in) and with Optimized Charging enabled. It would limit the max charge to 80% but every 6-7 days would drop a percent. So from 80% it would go down to 79% after 6 days and then 78% after another 6 days, etc. With both the Apple charger and Element Hub connected, the charge has been holding at 80%. "System Information" shows that the charger being used is the 70W Apple Charger and is not currently charging because of the Optimized Charging limit.
How are you charging the MacBook? MagSafe, Apple charger with USB-C, or powered USB-C hub that has the ability to charge? Do you have any powered USB-C hubs connected while charging?My work MacBook Pro is now showing 77% charge but this is after a few weeks of not rebooting the machine. The battery life is at 88%. This is after about a year and a half of service, mostly plugged in with the occasional off power brick computing.
It's been 10 days since my last restart and the charge is still at 80%. I got the Element Hub 8 days ago. By this time, without the Element Hub connected, I would be down to 78-79%. Something is charging the MacBook to keep it at 80% even though System Information is saying only the 70W Apple charger (with MagSafe) is being used to charge the MacBook and is not currently charging.Apple power brick only (USB-C to MagSafe ending). I'm pretty old-school in that I have no other USB devices attached. HDMI to (usually) my wife's 49" TV is the only other connection.
My M2 Air's battery typically stays at 78% - 80% while plugged in and on my desk. I use a Satechi 160W fast charger w/4 USB-C ports. The battery icon displays the little lightning bolt (charging), but I can't recall the last time the battery was 100%. I think this is just the way Apple's battery maintenance works.It's been 10 days since my last restart and the charge is still at 80%. I got the Element Hub 8 days ago. By this time, without the Element Hub connected, I would be down to 78-79%. Something is charging the MacBook to keep it at 80% even though System Information is saying only the 70W Apple charger (with MagSafe) is being used to charge the MacBook and is not currently charging.
