Hey,
So we have an old version of Plesk that I can't seem to get a qmail issue resolved (451 qq crashed (#4.3.0) ) so I was going to change to postfix and forget my problems existed. However I'm running into this problem:
I am no linux guru so I'm hoping someone here can help me downgrade 'cyrus-sasl-lib' package to version 2.1.22-5.el5_4.3...
Thanks in advance.
Code:
/usr/local/psa/admin/sbin/autoinstaller --select-release-current --install-component postfix
File downloading products.inf3: 100% was finished.
File downloading plesk.inf3: 10%..21%..32%..40%..51%..60%..70%..80%..90%..100% was finished.
File downloading ppsmbe.inf3: 18%..28%..49%..59%..70%..80%..90%..100% was finished.
File downloading sitebuilder.inf3: 10%..22%..35%..48%..61%..74%..87%..100% was finished.
File downloading sso.inf3: 10%..24%..37%..51%..64%..78%..100% was finished.
File downloading setemplates.inf3: 19%..100% was finished.
File downloading pp-sitebuilder.inf3: 10%..21%..31%..40%..51%..72%..93%..100% was finished.
File downloading billing.inf3: 11%..21%..30%..40%..50%..60%..70%..80%..99%..100% was finished.
File downloading mysql.inf3: 44%..100% was finished.
File downloading apache.inf3: 100% was finished.
File downloading nginx.inf3: 22%..34%..46%..59%..100% was finished.
Checking for installed packages...
File downloading PSA_9.5.4/plesk-9.5.4-cos5-x86_64.inf3: 10%..20%..30%..40%..55%..62%..76%..84%..90%..100% was finished.
File downloading PSA_9.5.4/plesk-patches-9.5.4-cos5-x86_64.inf3: 12%..25%..33%..42%..51%..68%..72%..81%..90%..100% was finished.
Parallels Containers were detected. Trying to connect to VZAgent...Warning! Failed to connect to VZAgent: ioctl: Transport endpoint is not connected
Detecting installed product components.
Gathering information about installed license key...
Retrieving information about the installed packages...
File downloading PSA_9.5.4/dist-rpm-CentOS-5-x86_64/build-9.5.4-cos5-x86_64.hdr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% was finished.
File downloading PSA_9.5.4/update-rpm-CentOS-5-x86_64/update-9.5.4-cos5-x86_64.hdr.gz: 10%..20%..30%..40%..50%..60%..70%..80%..90%..100% was finished.
File downloading PSA_9.5.4/thirdparty-rpm-CentOS-5-x86_64/thirdparty-9.5.4-cos5-x86_64.hdr.gz: 11%..22%..34%..40%..52%..60%..72%..81%..90%..100% was finished.
Determining the packages that need to be installed.
ERROR: Unable to install the "psa-mail-pc-driver-1.0.0-cos5.build95101209.08.x86_64" package.
The following could cause the installation failure:
1) psa-mail-pc-driver-1.0.0-cos5.build95101209.08.x86_64: No suitable solutions were found
for the "cyrus-sasl-md5" dependency.
2) cyrus-sasl-md5-2.1.22-5.el5_4.3.i386: No suitable solutions were found
for the "cyrus-sasl-lib = 2.1.22-5.el5_4.3" dependency.
3) Unable to downgrade 'cyrus-sasl-lib' package to version 2.1.22-5.el5_4.3:
version 2.1.22-7.el5_8.1 is currently installed.
There were also other problems encountered. For details,
refer to the log file: /tmp/autoinstaller3.log.
Not all packages were installed.
Please, contact product technical support.
Thanks in advance.
