Orthos or Prime?
brysig228
i have have both and when i ran prime95 for 4+ hrs at 3.4 i have no problem, no errors. but when i run orthos it locks up at the same speed, specs and all. ran memtest all night last night with no errors at 1:1 and default timing 5 5 5 18 2t with 2.0 volts. i have my vcore at 1.4555v and temp is at 22c idle and in the high 40c on load with prime and at orthos it goes around mid 50c. so should i not worry about orthos as long prime runs fine with no errors for more than 4 hrs? should i change any setting on my bios? thanks for any help.
Are you using Prime95 v25? The one that runs multi threads? If not Then you should trust Orthos since it does multi threads.
