I'm trying to sync one of my network shares to OneDrive.
I've created a symbolic link in my one drive folder to the network share - \\server\documents.
When you first launch OneDrive, it will sync everything properly.
After this initial sync, it stops syncing completey in either direction. If you kill onedrive and relaunch, it will one again sync everything up correctly and then stop syncing.
I've also tried mapping a network drive to the \\server\documents share with the same results.
Anyone else experience this sort of issue, or have OneDrive backing up network shares directly?
OS is Windows 7 in a VM with OpenIndiana serving the shares in ESXI.
