XBarbarian
- Dec 29, 2006
so... began the OC journey last night on my first new rig in 5 years..yay! what a upgrade..
upgraded the bios to 0902. thasts the most current bios I can find for the Gene-z...
one thing I think is odd..or maybe not; when I select the cpu level up.. the only options I have are auto, 4.2, 4.6
shouldn't there be a bigger range there? I see others speak about 4.5 etc...
So, thought I would start with the 4.2 and Ai Overclock Tuner = X.M.P.
that changes the vcore to "manual" @1.30 and sets the ram to 1600 @1.5
boot into windows..and even though the speedstep lowers the proc down to 1,600 at idle...the vcore stays put, I guess that's because of the manual "canned cpu level up"
so, Ive been been reading the off set thread here..
off set oc thread
hoping that maybe that would be the way to have the vcore lower when the proc idles...but seems some of his menu options are different?
with this oc to 4.2 and steady 1.3 vcore, and the H80 cooling in my rig set top medium, I idle at 40c, get to 60c with a IBT stress run
should I just be happy with that? seems like I should be able to get the vcore to lower at idle ... and 40c seems a little high for idle too ( thats read from HWare Monitor.. )
I can start lowering the manual cpu volts and find a stable voltage.. but how can I see that it lowers the vcore when the proc idles?
off set oc thread
