No audio on some programs but not others on two devices using Yamaha RX-V385... I have no ideas?
atarione
So a few years ago I got a RX-V385 4K HT receiver as a xmas gift, For some time it worked fine but now it is doing something that is absolutely baffling.
On my Roku Ultra some programs on the same app (netflix for example) will play audio fine but others programs on netflix will not have audio unless I uplug everything and restart the TV / Roku and Receiver. This device is plugged into the receiver directly (using eARC out to the TV).
I also have a Firestick TV that I got super cheap because of the roku problems this device is plugged into the TV and sends audio back to the receiver via the eARC, it does the exact same thing, some programs will have audio and others will have no audio unless I power everything back off and on again.
The audio will generally then work again for some time and then it will do the exact same thing...
all of the cables are supposedly rated for 4K ... I have tried switching cables anyway and this issue persists... anyone have any thoughts on this? Firmware is up to date on all devices btw.
So are you using external speakers with the receiver? If you're doing Roku -> AVR -> TV then it's not using eARC, unless for some reason you're pushing audio through the TV speakers. But in that case, why even use a receiver?
Are there differences in the audio type between shows (Dolby, DTS, etc.)?
Right fair enough... yeah I guess you are right the eARC isn't really in play with the Roku... yes the Receiver is hook up to some vintage Klipsch speakers
Roku audio = Auto (DD+ / DTS-HD)
Firestick = Best available (PCM , Dolby Digital + , Dolby Digital)
A TV restart is likely unnecessary.
As you are dealing with two different sources, I'd suspect the AVR.
