But seriously.
~250k out of a single GPU?!
Nope the first 1,000,000 PPD rig would be a 4P with 1 or 2 GPU's an 8102 and 1- GTX 580 running a 8047 would get you there.
Better find those Sr-2's and asus Z9 boards with 7 pcie slots, Thats north of 100k ppd on smp and then a shit ton more on 4 or 5 gpu's. Theres your 1st 1m PPD rig
4 x GTX 690's on a single motherboard?
Hohoho... first 2 million ppd machine! (or more... if these units prefer 1536 newer 600 series cuda cores vs. 512 of the 500 series cores)
But seriously... almost 250k ppd from a 580??
Why not, Atlas used to run 4 x GTX 295 on multiple mobo's
Maybe I'm missing something - but is nVidia GPU folding now back in a huge way? If I want folding on a tight budget and like playing games on the side, would a GTX 670 do more folding than a 3770k would?
If they leave the current beta testing GPU points system as is when they release to the wild, the yes a 670 will do 2-4 times the PPD of a 3770k depending on the WU.
these are the first results of the beta testing though. Unless Stanford can prove that GPUs are that much more efficient at folding than SMP, they will have to adjust the points unless they want over a years work in developing QRB for GPU to blow up in their face from angry CPU/multi-proc Folders.
Lets give it some time. Though this is Stanford, so who knows what they will do.
I think the problem is that the GPUs can be this much more efficient than SMP, they're just harder to program for. When considering DP FLOPS numbers I think a 4p system is fairly similar to GPU. Their molecular dynamics type of problem works very well in a highly parallel environment and GPU was really their big game changing technology a couple years ago. Bigadv kind of screwed that. I can't wait until GPU folding with big multi card systems is back, it will just suck if they screw with the points system for everyone who built around bigadv.
- that's the problem with the points system and enthusiast, competitive people. These people invest big bucks and lots of time in chasing the most points and pushing the envelope of what their hardware can do.
when a game changing thing like GPGPU comes along, those people are left feeling out in the cold.
You know - points be damned... I just want to fold the important stuff for the sake of science and killing the evil cancerous beast!
I fold for a cure, the points are a nice little earner for my competitive side, but I really don't care for them. If I had investing $1000s in hardware like many have, no doubt I would care more.
If GPU folding does a million tiny, nearly-useless jobs and CPU folding does the "important stuff" I'll still aim in that direction.
The whole point is that now we can do the same work on GPUs as on SMP. If GPU is that much more efficient at doing the work than SMP, then points should reflect that.
Stanford should be encouraging people to Fold in the most efficient manner possible.
This is crazy. A 10x overnight increase in the points given for one particular type of work is stupidity.
I have 6 460s spinning on beta but haven't seen a single one of these yet. I expect this is down to the masses using the beta flag to get WU for their Kepler GPUs. As PG now use a whitelist for the GPUs, I expect this should be how the beta WU distribution ought to work as well.
Dear DAB rep (Kendrak?), please pass this on, as it really kills the usefulness of beta testing if actual registered beta testers can't get beta WU to, you know, test.
How do you set the beta flag on v7 for a GPU? I have two 460s and a 560Ti folding but have never set the beta flag for GPUs.
I know the significantly higher points for these WUs are exciting/frustrating but let's not forget that this is just the first step in PG's effort to give "equal points for equal work". I'm all for it!
I can only hope they finalize this initiative as soon as possible, without causing too much confusion and chaos.
