Hello. I just finished putting a system together yesterday.
i5 4670k
H80i heatsink
Asus z87-a
Corsair hx750
Gskill ripjaws 12800cl 16gb kit ( x2 8gb)
Samsung 840 250gb
I assembled it yesterday, had no problems booting up right away and going into BIOS. I installed windows then, installed the Asus suite software and did windows updates/drivers. So then I restarted into BIOS to do some overclocking. Tried for 46 multiplier to see if I was lucky, ended up failing. So tried to do 44 and it restarted like normal, but now there's no video on my display, planar sa2311w.
This is mainly my issue, the CPU led light is on on the mobo.
Tried clearing cmos with jumper, take battery out for 15 seconds. Unplugged 24 ping and 8 pin power and reconnected, reseat the CPU and thermal paste after multiple tries of trying toreset it. Just every time I start there's no video and the CPU led light is on. Any ideas?
i5 4670k
H80i heatsink
Asus z87-a
Corsair hx750
Samsung 840 250gb
