I have a customer that is wanting a 3 way redundant link between private sites. The primary connection will be via T1/E1, the the second will be via a microwave link, the third will also be over a microwave link.
If the first link fails then it should switch over to the second link and if the first and second fails then it should failover to the 3rd link.
All three links will be configured as an ethernet bridge so we will have an ethernet connection from each link to work with. There is no Internet connectivity across the links, only private traffic.
Does anyone here have any experience with configuring something such as this or can you recommend a vendor that has experience that I could work with?
