Ok. Cisco Guys / Gals / Gods...
I'm wondering if this is even possible, but I have a client that is joing in on a new fiber circuit in their area that will allow them better internet than that current isp (30down / 30 up is what they will end up with). Also with the internet is a couple of private research networks that will go along with the internet.
We have to provide a router for connectivity. We have on order an 1841 with advanced security ios. One port on the 1841 turns into a trunk port for their side of the connections (they have vlanned off all of the appropriate networks) and the other side of the connection is for our lan.
What I want to do through the router (or some other device depending on cost) is to split the bandwidth off in something like 90%/10% between our internal network and our guest access network.
Not sure if this is anything at this point, but the dsl circuit is 4 mb down / 512 up and is currently split with a unamnged 5 port switch going into the wan ports of 2 firewalls (1 firewall for internal and the other for the guest access).
Thoughts?
Thoughts?
