Yea sounds silly, but I have several raid cards and those Adaptec 5 series gets about 100 degrees which is apparently fine according to Adaptec but my sound cards doesn't appreciate the crispy winter tan ..
I am currently planning in building my first water cooling system and why not a raid card ey
Anyway, the card has two holes above and below the heatsink.
The holes are 4.5cm / 45mm / 1.773inch apart.
Can anyone / someone suggest a water cooling block which should fit on that ? I was thinking about a North Bridge cooling block but it appears the standard holes are a bit too far apart.
Any help is appreciated.
Here a few pictures from both sides
