Daedalus454
- Jul 16, 2008
I've been using my MSI GTX970 (the black 4GD5T OC version) since November with no issues in my Silverstone TJ-08E mATX case, running everything at pretty much max settings at 1920x1200. It got a little warmer than most reviews showed the TwinFrozr V getting, but I figured it was natural to run a little warm in a mATX case.
Well, I bought myself a 21:9 3440x1440 monitor a few weeks back, and now my GTX970 is running at a pretty consistent 80-81 degrees per MSI Aferburner (I thought these cards would throttle at 80 - no idea how I got to 81) in demanding games like Tomb Raider and Bioshock Infinite. The aluminum side panels of my case get hot to the touch right around the video card.
I knew the extra pixels of the new monitor would force the card to work harder, but I wasn't expecting this.
Granted my den/office tends to sit around 75F / 24C ambient temps in the summertime (the AC in this place is def. lowest bidder junk), which might be a contributing factor.
I double-checked the manual for my case, and Silverstone does recommend using only blower style video cards in this case.
So my question is, is this actually a problem? If it is a problem, would buying a card with a blower style cooler be likely to help?
