MSI Gaming Trio NVIDIA GeForce RTX 4090 - Temp Check
sk3tch
Yo!
Got this from the sketchiest of sketchy sources and everything seems OK - but these temps do seem a bit high? Thoughts?
Should I see any thermal throttling on a 4090???
Workload is Time Spy stability test (run of 20) and a round of Fortnite with Lumen on high (RTX heavy)…
Misplaced a gpu support bracket once that stopped the third fan on a gpu. Noticed temps were above normal pretty quick so no harm done. Might be worth a quick look.
These are the max temps I get after running Time Spy Extreme, Speed Way and Cyberpunk 2077 benchmark at max settings with path tracing and DLSS.
The 4090 is undervolted 2800MHz @ 975mV and +1000MHz to the VRAM. Case is the Asus ProArt PA602. Ambient temp is around 26C.
I have the same card and those numbers look pretty close to what I see when the card is under duress.
FYI - The gaming x trio doesn't have a vapor chamber cooler.. just a normal heat pipe cooler on it.
