have you thought about using a modular power supply to help get rid of all those cables?
Terra-Crusher here.Thanks T-maxx! Stay tuned for more updates.
PS: I was a big t-maxx fan in college. But stadium trucks were my bread and butter.
That vent actually turned out a lot better than I would've thought -- did you consider maybe tapering off the number of holes toward the sides (make it more rounded) or maybe flare out a little toward the back to follow the lines of the case?
too late now, but careful with having too open a case, though it'll cool you're system well it'll equal alot of noise filtering out from the fans and components.
The new front panel looks nice. Are you going to keep it with a metal finish or will that become flat black aswell?
Here's a crazy idea: what if I did the final cleaning stage of the case and misc. parts... in the dishwasher??? I figure with the plastic pieces on the top shelf (away from the heating elements) and everything else on the bottom, a nice hot high pressure bath would clean it up quite nicely! Doesn't seem like it would do the dishwasher any harm. Because what else does a dishwasher do but clean greasy, nasty metal and glass objects?! Right!? I'll think about that one...
2) I got nothin'. Brass is too slender for case feet, and too small for most anything else. Maybe get your metalworking on and beat a mess of it into a panel for a future mod?
